2001 Santa Fe Fog Lamp replacement?
How do you replace the bulbs in the fog lamps on a 2001 Santa Fe?
RE: 2001 Santa Fe Fog Lamp replacement?
2001 > G 2.4 DOHC > Body Electrical System http://www.hmaservice.com/viewer/img/email_icon.gif http://www.hmaservice.com/viewer/img/print_icon.gif REPLACEMENT OF LAMPSHEAD LAMP/TURN SIGNAL LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Remove the head lamp mounting bolts and remove the head lamp assembly.[/align]http://www.hmaservice.com/data/Passe...G/esja005b.gif3.Installation is the reverse of removal.[/align]FRONT FOG LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Remove the head lamp mounting bolts and remove the head lamp assembly.[/align]http://www.hmaservice.com/data/Passe...G/esja005b.gif3.Remove the screws in the front bumper cover.[/align]http://www.hmaservice.com/data/Passe...G/esja005c.gif4.Raise the vehicle then remove the screws holding the front bumper and the front wheel guard.[/align]http://www.hmaservice.com/data/Passe...G/etja190a.gif5.Remove the front fog lamp from the bumper cover.[/align]http://www.hmaservice.com/data/Passe...G/etja010h.gif6.Installation is the reverse of removal.[/align]REAR COMBINATION LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Open the tailgate and loosen the screws holding the rear combination lamp.[/align]3.Disconnect the connector and remove the lamp assembly.[/align]4.Installation is the reverse of removal.[/align]http://www.hmaservice.com/data/Passe...G/esja010c.gifCENTER HIGH MOUNTED STOP LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach 2 blanking covers on both sides of the lamp.[/align]3.Remove the two mounting screws.[/align]http://www.hmaservice.com/data/Passe...G/esja040n.gif1.Disconnect the connector and then remove the lamp assembly.[/align]http://www.hmaservice.com/data/Passe...G/v5be075i.gif2.Installation is the reverse of removal.[/align]LICENSE PLATE LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Remove the mounting bolt, and disconnect the lamp connector.[/align]3.Installation is the reverse of removal.[/align]http://www.hmaservice.com/data/Passe...G/esja040e.gifMAP LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach the map lamp lens.[/align]http://www.hmaservice.com/data/Passe...G/etja010l.gif1.Detach the lamp assembly from the headlining after removing the screws.[/align]http://www.hmaservice.com/data/Passe...G/esja050m.gif2.Disconnect the connector from the roof harness.[/align]3.Installation is the reverse of removal.[/align]ROOM LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach the room lamp lens.[/align]http://www.hmaservice.com/data/Passe...G/etja010k.gif1.Detach the lamp assembly from the headlining after removing the screws.[/align]2.Disconnect the connector from the roof harness.[/align]3.Installation is the reverse of removal.[/align]LUGGAGE LAMP[/align]1.Using a flat-bladed screwdriver detach the luggage lamp lens.[/align]2.Detach the lamp assembly from the headlining after removing the screws.[/align]http://www.hmaservice.com/data/Passe...G/v5be075p.gifREPLACEMENT OF LAMPSHEAD LAMP/TURN SIGNAL LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Remove the head lamp mounting bolts and remove the head lamp assembly.[/align]http://www.hmaservice.com/data/Passe...G/esja005b.gif3.Installation is the reverse of removal.[/align]FRONT FOG LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Remove the head lamp mounting bolts and remove the head lamp assembly.[/align]http://www.hmaservice.com/data/Passe...G/esja005b.gif3.Remove the screws in the front bumper cover.[/align]http://www.hmaservice.com/data/Passe...G/esja005c.gif4.Raise the vehicle then remove the screws holding the front bumper and the front wheel guard.[/align]http://www.hmaservice.com/data/Passe...G/etja190a.gif5.Remove the front fog lamp from the bumper cover.[/align]http://www.hmaservice.com/data/Passe...G/etja010h.gif6.Installation is the reverse of removal.[/align]REAR COMBINATION LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Open the tailgate and loosen the screws holding the rear combination lamp.[/align]3.Disconnect the connector and remove the lamp assembly.[/align]4.Installation is the reverse of removal.[/align]http://www.hmaservice.com/data/Passe...G/esja010c.gifCENTER HIGH MOUNTED STOP LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach 2 blanking covers on both sides of the lamp.[/align]3.Remove the two mounting screws.[/align]http://www.hmaservice.com/data/Passe...G/esja040n.gif1.Disconnect the connector and then remove the lamp assembly.[/align]http://www.hmaservice.com/data/Passe...G/v5be075i.gif2.Installation is the reverse of removal.[/align]LICENSE PLATE LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Remove the mounting bolt, and disconnect the lamp connector.[/align]3.Installation is the reverse of removal.[/align]http://www.hmaservice.com/data/Passe...G/esja040e.gifMAP LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach the map lamp lens.[/align]http://www.hmaservice.com/data/Passe...G/etja010l.gif1.Detach the lamp assembly from the headlining after removing the screws.[/align]http://www.hmaservice.com/data/Passe...G/esja050m.gif2.Disconnect the connector from the roof harness.[/align]3.Installation is the reverse of removal.[/align]ROOM LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach the room lamp lens.[/align]http://www.hmaservice.com/data/Passe...G/etja010k.gif1.Detach the lamp assembly from the headlining after removing the screws.[/align]2.Disconnect the connector from the roof harness.[/align]3.Installation is the reverse of removal.[/align]LUGGAGE LAMP[/align]1.Using a flat-bladed screwdriver detach the luggage lamp lens.[/align]2.Detach the lamp assembly from the headlining after removing the screws.[/align]http://www.hmaservice.com/data/Passe...G/v5be075p.gif [/align] findme('); findme('); findme('); [align=left] [/align]
