2001 Sante Fe Sound System changes modes
I have been having several problems with my sound system in my 2001 Sante Fe. First, the digital display at times will not show all characters, however if you lightly tap on the display, they all appear. Also, the system changes modes from radio to CD player or the audio just cuts out all when the vehicle hits a bump in the road ( living in PA that happens alot!). I need to know how to get the radio out of the dash so I can either get it repaired or replaced.
Thanks Ken K. |
RE: 2001 Sante Fe Sound System changes modes
I need to know how to get the radio out of the dash so I can either get it repaired or replaced. 2001 > G 2.7 V6 DOHC > Body Electrical System REMOVAL AND INSTALLATION 1.Disconnect the negative (-) battery terminal.[/align] 2.Remove the ash tray and then remove the screws holding the center facia panel.[/align] http://www.hmaservice.com/data/Passe...G/esja035h.gifhttp://www.hmaservice.com/data/Passe...G/esja035j.gif 3. Remove the center facia panel and disconnect the connectors.[/align] 4. Remove the screws holding the audio and remove the audio assembly from the mounting bracket.[/align] http://www.hmaservice.com/data/Passe...G/esja035i.gif 5.Installation is the reverse of removal.[/align] |
