2004 Santa Fe code p0430
Old 08-22-2018, 04:35 PM
Roz's Avatar
Roz
Roz is offline
Default 2004 Santa Fe code p0430
Does this code automatically means to change the catalytic converter?
Old 08-22-2018, 11:28 PM
avisitor's Avatar
The diagnostic trouble code only points to where the issue is
You have to test. Low efficiency of the cat could mean the O2 sensors are not working correctly
Or wiring is suspect. Sometimes, using "Cataclean" will help??
But, if you've got the money to change it???
Old 08-23-2018, 08:41 AM
Can you help us out a little here?
Have there been any other problems, like misfire, at any time , engine running rough?
This is important because that history may point to why the code is now coming up Any unusual performance problems ?
Old 08-27-2018, 12:36 PM
Roz's Avatar
Roz
Roz is offline
ok replaced the o2 sensors will see how that’s goes
Old 08-27-2018, 12:37 PM
Roz's Avatar
Roz
Roz is offline
no other problems, no misfire no engine not running rough
Old 08-27-2018, 10:21 PM
avisitor's Avatar
I never recommend changing parts without testing
Usually this require a higher level scanner
Anyway, let us know how it goes
Nayth
01-31-2024 09:55 PM
mhelm2359
01-02-2018 10:59 AM
nscrnt88
01-17-2011 10:32 AM
took
03-26-2010 09:07 AM
itpphoto
12-29-2007 09:50 PM
Quick Reply: 2004 Santa Fe code p0430
