2005 Santa Fe
My ABS,TCS and brake lights come on at about 65 miles and he all the time and only go off when engine is shut off. I had new brakes put on and nothing change, what can be the problem?
Does your cruise control work?
There is a recall for the brake light switch on the brake pedal. It controls not just the brake lights but the TCS, ABS and cruise control. Take it to a dealer for a free replacement. Tell them you are bringing it in for the brake light switch recall. |
yes my cruise works but it has shut off in the past for no reason. Thank you so much. I looked for any recalls but didnt see this one.
(Post 26643)
There is a recall for the brake light switch on the brake pedal. It controls not just the brake lights but the TCS, ABS and cruise control. Take it to a dealer for a free replacement. Tell them you are bringing it in for the brake light switch recall. Wrong application !! Campaign 092 does not apply to 2005 model or 2006 (SM) , 2007 (CM) is applicable. I would be more concerned with a loose/cracked tone ring at the front axles.... scan for codes first. and not at Auto Zone, need HI-SCAN or GDS to access them module for code(s) -- dealership -- |
| All times are GMT -5. The time now is 05:44 AM. |
