-   -   2008 santa Fe foglight bulb replacement (https://www.hyundaiforum.com/forum/hyundai-santa-fe-20/2008-santa-fe-foglight-bulb-replacement-5136/)
DMS4420 Nov 24, 2008 10:33 AM
How do you replace the fog light bulb on a 2008 Santa Fe? What is the bulb number (so I can purchase it)?
ken99 Nov 24, 2008 09:38 PM
RE: 2008 santa Fe foglight bulb replacement
REPLACEMENT
1.Disconnect the negative (-) battery terminal.[/align]
2.Remove the front side cover screw.[/align]
3.Remove the front fog lamp assembly (A) after loosening screws (4EA).[/align]
http://www.hmaservice.com/data/Passe...scmbe6441d.gif
4.Installation is the reverse of removal.[/align]
Page 6-31 of the owners manual indicates a 27 watt halogen with a PG13 base. That translates to type 880 halogen bulb. However, the PG13 base on the 880 is straight and the bulb in the diagramn has a 90 degree bend in the base. That would be a PGJ13 base on a type 881 bulb. You might want to pull an existing bulb out first to make sure. If the harness has enough play in it, either may work just fine.
