2008 Santa Fe Headlight issue
2008 Santa Fe w/2.7L and automatic trans.
When slowing down, the headlights dim briefly. This appears to be only happening when the transmission downshifts but is extremely noticeable from 2nd to 1st shift. The rear lights and the interior do not dim; only the headlights. I have noticed a quick dip on the tach when this happens. Dealer says could be battery but tested as good. Any ideas? This is becoming a little annoying as I drive in stop and go traffic usually in the dark. |
RE: 2008 Santa Fe Headlight issue
Sounds like you have a lot of load on the system like headlights, heater fan, wipers, etc all going at the same time. Battery might need a charge, but it's not an "abnormal" thing in winter at night.
When slowing down, the headlights dim briefly. |
ORIGINAL: jsinton Sounds like you have a lot of load on the system like headlights, heater fan, wipers, etc all going at the same time. Battery might need a charge, but it's not an "abnormal" thing in winter at night. [align=left][/align] |
ORIGINAL: ken99 When slowing down, the headlights dim briefly. You've both been very helpful. |
