2009 Sante Fe interior light setting
Dont know if some family member is screwing around with the interior light settings or not.
Have got the cargo light coming on when opening the drivers door, but the light above the center console doesnt come on... I have it set exactly the same as the 2010 Sante Fe we just got and still doesnt work... I have the button marked "Door" pressed in as in the 2010...nothing...Both of the spots still work, drivers light and passengers light.... Something I am missing here???? Thanks |
you may need to switch on the cargo light to the door position. the center light push the door button. I have a 2010 also. i have no issue. then you have the door button on the roof consol in the center. push that also.
chris 2010 sante fe |
might be a bad bulb
