Code p0302
Code p0302
2001 Hyundai Santa Fe 2.7 getting code p0302 on cold start...start and cuts off...any ideas why.
I had the plugs,wires,injectors,fuel pressure regulator,ignition coils changed...the car runs great til it gets cold and then I get the p0302 code and cuts off after I start it.....
P0302 is a misfire on cylinder two code
Depending upon how bad the misfire is, it can cause the engine to shut down.
Need to do a few tests to determine what the issue is.
Whether it is a bad coil or bad spark plug or vacuum leak.
Would take brake clean and carefully spray around intake manifold near cylinder 2
Would check spark from coil. replace spark plug????
blackbox19
08-06-2010 09:59 PM
