2004 Santa Fe code p0430
The diagnostic trouble code only points to where the issue is
You have to test. Low efficiency of the cat could mean the O2 sensors are not working correctly
Or wiring is suspect. Sometimes, using "Cataclean" will help??
But, if you've got the money to change it???
Can you help us out a little here?
Have there been any other problems, like misfire, at any time , engine running rough?
This is important because that history may point to why the code is now coming up Any unusual performance problems ?
ok replaced the o2 sensors will see how that’s goes
no other problems, no misfire no engine not running rough
