2014 headlight dim
Old May 23, 2023 | 08:51 PM
Reinel's Avatar
Default 2014 headlight dim
Hello, The headlight turn on but they are dimmed, I bought the new H7 at Hyundai representative and the problem persist. I bought a second pairs of H7 on Amazon and show a little improvement.
I bought a third pair H7 LED and does not work, the clip holder does not fit at all.
Now I bought a new set of H7 LED from Auxito, that does not requiere ante clip holder.
I red about this problem and some mechanic said, check the ground, But the ground is good.
If someone has any idea about the subject, I will appreciate your comments.
Thanks.
Old May 24, 2023 | 07:10 AM
Does it have the same problem with high and low beams?
Old May 24, 2023 | 04:10 PM
Reinel's Avatar
Hello, just with the High beam, low beam and bright beam work well
Old May 25, 2023 | 06:12 AM
This may be a little more involved than we would like. WHY ?
If vehicle has Daytime running lights that module could be involved. DRL utilizes the hi beam system.
Old Jul 10, 2023 | 07:26 PM
Reinel's Avatar
Hello, this santa fe version doesn't have DRL System
Old Jul 11, 2023 | 04:40 AM
Are you sure?
A lot of vehicles vehicles older than yours came with that feature.
Could it be the system just is not working?
Did you buy it new or used?
Old Jan 15, 2024 | 02:38 PM
Reinel's Avatar
Hello World, I Finally got the problem with the dim lights, I bought a new lamp in Amazon, and I paid for the installation and the dim light gone.
I resolved it by accident because I was checking the bulb and the plastic base that hold the base lamp was cristalizade due to the hot and made a plastic dust in my hand, after that I bought a new lamp.
pittguy
Sep 26, 2021 04:22 PM
Gavin Rey
Feb 16, 2018 11:35 AM
KT418
Oct 12, 2014 06:48 PM
n707jt
Aug 18, 2009 07:35 AM
holt3332
Jan 10, 2009 10:50 PM
