2014 Santa Fe will crank and run but won’t come out of park
Old Jun 23, 2019 | 11:08 PM
Davidkita1201's Avatar
Default 2014 Santa Fe will crank and run but won’t come out of park
I have a 2014 Santa Fe that has been perfect! Went to leave earlier and it wouldn’t come out of park. It cranks and everything works except for the dashboard and the ac blows hot instead of cold. It won’t shift into gear when mashing the brakes. But we can shift it using the shift lock release. The ABS light is on, check engine light, and the emergency brake light is on. All fuses are good. What could this be??
Old Jun 24, 2019 | 06:45 AM
allegretto's Avatar
I guess there is a short in the wiring somewhere.
Old Jun 24, 2019 | 02:31 PM
avisitor's Avatar
Is it still under warranty?
If yes then have dealer fix it
If not then check all fusible links and fuses
Swiper99
Apr 4, 2018 03:35 PM
scottsantafe2.0
Feb 26, 2014 11:44 AM
oxjayxbeexo
Sep 14, 2011 07:25 AM
kslim
Oct 22, 2008 01:26 PM
poch
May 3, 2006 11:11 PM
