2016 Santa Fe, Reverse Light Wire
I need to tap into the reverse light wire for a my 2016 santa fe in order for my surge brakes on my boat trailer to properly work while I am in reverse. I can only find the circuit in both the hood fuse panel and the actual reverse light compartment located in the hatch. Neither of these places are any good for running a wire back to my tow wiring harness. Does anyone know where I can tap into this wire. Does the wire from the hatch run over to the inside cargo area panel? If so, how do I remove that panel?
Reverse for surge brakes
Originally Posted by marshallcp77
(Post 52674)
Tekonsha 118269 4-Flat Tow Harness Wiring Package with Circuit Protected ModuLite HD ModuleCURT 57187 4-Way to 5-Way Flat Adapter for Boat Trailer Surge Brakeshttps://cimg3.ibsrv.net/gimg/www.hyu...a9e2eeab08.jpg Plug up above headliner where I patched into the reverse wire. https://cimg5.ibsrv.net/gimg/www.hyu...7260117114.jpg reverse wires in the hatch at the back of the reverse light. Red is 12v for reverse https://cimg6.ibsrv.net/gimg/www.hyu...0ff5997d17.jpg Route for the wire to the base of the rear hatch area. |
