2023 Santa Fe Heater Problem
The heater in our 2023 Santa Fe Caligraphy model doesn't blow air out of the vents in the dashboard. It does blow warm air through the defroster vents so I'm assuming it's not a thermostat problem.
Has anyone else had this problem and gotten it resolved? We have a service call scheduled but I'd like to know more about this in case the mechanic hasn't run across the problem before. Thank you ScottC Saluda, NC |
Dealerships have access to all service bulletins and problems with fixes.. They should be able to find and repair whatever needs to be repaired.
They are required to have people factory trained or they don't get reimbursed for any warranty work. You can provide all the symptoms and conditions, but leave the diagnosing and repair to the tech that gets assigned the problem. |
I have the same issue with a 2023 SEL.... The dealer diagnosed it as a failed mode door actuator. They ordered the part and I am scheduled for a 5-10 appointment to replace it.
If warm air is coming through the defroster vents but not through the dashboard vents, it suggests that there may be an issue with the airflow distribution within the HVAC (heating, ventilation, and air conditioning) system. Here are a few possible auto causes :
Originally Posted by gdf44
(Post 65021)
In my case replacement of the mode door actuator (4+ hour job) resolved the issue described by the OP |
