Horn location 08 Santa Fe
Old 07-17-2018, 07:26 AM
Kenny Kutch's Avatar
Default Horn location 08 Santa Fe
Are the horns under the headlight assembly like the earlier models or are they behind the front bumper cover? One of them blew and I got this high pitched nearly inaudible sound coming from my horn.
Old 07-17-2018, 07:35 PM
Check behind the front bumper area.What happens is, moisture gets blown into the horn and it gets harder and harder to vibrate and "work'.
Sometimes you can get it to work better again if you tap it a few times to free up the vibrating pieces. If that fails replacement may be the only alternative.
Covering the horn with a towel or rag will help protect your sanity if it decides to work while you are still under the front of the vehicle.
Old 07-18-2018, 11:29 PM
thanks I'll check it out. What do you think about using compressed air to clear it out?
Getzbetter
01-06-2013 02:07 PM
tiffmarieu85
08-23-2012 08:13 PM
Henhead
04-28-2009 10:12 PM
Al
10-31-2006 12:04 AM
megs63
10-12-2006 03:23 PM
Quick Reply: Horn location 08 Santa Fe
