Air conditioning and heating troubles
I have a 2003 Santa Fe. After running the Air conditioner or Heater for about 30 minutes, The airflow changes and does not flow through the vents. It seems like it blows behind or in the dashboard. Any Ideas why?
RE: Air conditioning and heating troubles
do you have the automatic climate control or manual?
I havea manuel controls. It does not seem to matter if I have it on low or high. Thanks for your help!
what is happening is that the system goes in fail safe mode. it's a problem with the blend door actuator. just to check, when it changes modes, does it blow in defrost and floor?
Did we find a solution?
Originally Posted by mcclekw
(Post 11048)
