alternator replacement
Hi All,
Have an 02 Santa Fe, 2.7L. Appears I have an alternator issue as the voltmeter drops to nearly 8volts while idling with lights, a/c and radio on. With everything off it's in the 11volt area. My concern is how to take the wheel well off in order to access the alternator and slightly any belt tension adjustment I might need to make as I'd replace the belt when I'm replacing the alternator. Anywhere I can get this info online etc w/o paying for it? Thanks all, James |
