BCM location
2012 santa fe 4 cyl. When I pull off my interior fuse box cover, there are 3 major components, the first thing is the oem remote start module, behind that is the fuse box, behind the fuse box is a plastic box thats mounted in a bracket, is this the bcm? If it is, what is the spring loaded stalk thats mounted with it? It looks like it might be a shock sensor. Is there a fuse inside the bcm?--- thanks
Probably. It looks like this:
http://i.ebayimg.com/00/s/MTIwMFgxNj...TsbZu/$_57.JPG http://i.ebayimg.com/00/s/MTIwMFgxNj...TsbZ3/$_57.JPG It's not a shock sensor it's the antenna for the keyless entry fobs. What are you trying to do? |
nova
This a continuation of my antitheft post on 7-8-2014.I put in oem fog lites and oem switch. I remember accidently popping the dash lite fuse when I was doing the switch,I replaced the fuse and the dash lites worked, thats why I asked if there was a fuse inside the bcm. Im a little confused about 1 thing. I thought my antitheft sys was part of the remote start sys. Its an oem sys. it looks like it might have been dealer installed as part of the new car prep procedure, thats why I asked what the stalk was on the bcm. So I take the dash panel off again to ck my work and now my clock, radio, cig lighter and power terminals are inop. I have 4 inside fuses with no power on either side of the fuse. Im trying to find the power source for these fuses, audio 2 10 amp---cig lighter 15 amp---p-outlet center15 amp--- power outlet 25 amp. I dont have a lot of info. The local dealer told me that I cant a shop manual and elec manual in book form.
