-   -   Blue tooth (https://www.hyundaiforum.com/forum/hyundai-santa-fe-20/blue-tooth-9001/)
stonehedge Sep 3, 2010 08:31 PM
Blue tooth
just bought used 2009 santa fe limited. The blue tooth has multiple phones programmed in from previous owner. How do you delete all the phones? When I go in thru set up and say delete phone it says phone not avaialble (which it is not)...what do i do?
SFG Sep 12, 2010 08:39 AM
Try to remove the fuse for the nav system. This will power reset the unit. If you can't find the fuse disconnect battery lead wait 5-10 sec. then reconnect battery.
This should reset the unit.
