Brake light/ blinker problem.
Ok heres the deal. My right turn signal works fine unless the brake is pressed. The left works fine no problems. If the flashers are on and i press the brake the flashers stop on both sides. The brake lights work fine on both sides. Ive checked all the bulbs on both sides and everything is working fine. Its only a problem when im trying to use my right turn signal when the brake pedal is pressed the turn signal stops flashing and just lights up.
If anyone has had this same issue or might know what it would be itd be a huge help. I was thinking maybe the turn signal relay or maybe the brake switch... |
A bulb is bad. Did you check ALL the bulbs? Not just the ones in the tail lights. Check the front and side signal bulbs too.
Please post solution when you find it. That's the purpose of a forum. Sure sounds like one bulb in the system is shorting.
All bulbs have been replaced with the correct bulbs and are working. So i dont think its a bulb. Anyone else???
Just to calarify, did you check the front and side turn signal bulbs?
Nova are you being serious??? How many times do i have to say that YES i have checked all of the lights!!! All light bulbs are working. So does anyone else have any suggestions besides "check the bulbs"?
No we don't.
Originally Posted by gumby25
(Post 30363)
