Code P0010
2017 Santa Fe Sport 2.4
Anybody else getting this code ? P0010 And if so what was the fix. Thanks |
P0010 seems to be related to VVT or variable valve timing
It is a way to increase power and/or efficiency of the engine by way of using the oil pressure An OCV or oil control valve may be involved. I know there is an oil screen/filter thta usually needs to be inspected and/or serviced. Guess you can read about it just like I did?? |
Had it taken care of this morning. it was the cam cover - seals- sensor also there was a software update that was done. they said this is the first they've seen on a santa fe , mostly it's the sonata's
Does anyone by chance know where these are located on the 2017 Santa Fe sport 2.0?
