Confusing Transmission Dipstick Readings...
Old 10-25-2017, 06:47 PM
Mark R's Avatar
Default Confusing Transmission Dipstick Readings...
2004 Santa Fe GLS with 3.5 Liter V6 and 111,000 miles.
I bought it earlier this year, and it's been a great little vehicle.
When I check the trans fluid level, it reads WAY over full.
So I decided to go ahead and drain the fluid and change it out.
I expected to drain an excess amount, but only got 4 quarts.
I put only three quarts of new fluid back in and it's running fine.
But when I check it, it's reading way up on the dipstick again!
How the heck can that be..?!? Any suggestions for me?
Thanks very much!
Old 10-25-2017, 11:40 PM
avisitor's Avatar
Are you reading the transmission dipstick on level ground when the engine is running and the gear selector is in neutral?
If you are then you should know that the transmission is running fluid through
It won't show you the true level of fluid like that
Check your manual for the fluid capacity of the transmission
Old 10-26-2017, 10:00 AM
Mark R's Avatar
I'm checking it on level surface, warmed-up, engine idling in park.
That is how I have always checked automatic transmissions.
I'm pretty sure it needs to be running to show the proper level.
I just can't figure out why the stick gets so covered with fluid...
Old 10-26-2017, 11:35 AM
Mark R's Avatar
I have tried inserting the dipstick in at all different orientations.
(always thoroughly cleaning it in between each time, of course).
One side is always completely covered (like about 5" or 6" up).
The other side is not covered, but it does get spattered with fluid.
The spatters and streaks are enough to prevent a meaningful reading.
Old 10-26-2017, 09:12 PM
avisitor's Avatar
Well, what is the lowest place that doesn't get splattered? .. is your fluid level??
Old 10-27-2017, 03:16 PM
Mark R's Avatar
Yeah, I understand what you're saying.
But there is really no definitive line of fluid visible.
Even on that dry side it's still streaked and smeared.
I went ahead and put in the fourth quart of SPIII.
So at least I know it has the same amount as before.
And for sure it is much cleaner and refreshed now.
But I just wish I was able to know the exact level...
oceanwalker
11-24-2014 11:19 AM
mvftw
08-05-2010 11:25 AM
knightspeed
11-18-2008 02:07 PM
90excelGS
02-20-2008 12:33 AM
mrbill
11-16-2005 08:21 PM
Quick Reply: Confusing Transmission Dipstick Readings...
