Dash lights flicker when I apply the brakes
I have a 2007 Santa Fe ... The dash lights and radio light flicker when I apply the brake. Plus the left blinker doesnt work when lights are on but when lights are off it doesnt work when I apply the brake either. Need some advise please
Brake Actuation Lamp Issues
Mr. Bliss,
The facts you present could be related to many aspects of the car's wiring. Given that the brakes are integral to the problem, you might visually inspect the left and right brake lamp bulbs. I had a similar issue with odd dash lights and brake lamps that lit when the park or headlamps were turned on. When I applied the brakes, my dash lights lit up and the side marker lamps lit. The problem was one of the filaments in a dual filament bulb was "Laying" on the other filament. A new bulb fixed everything. Another thing you need to do is visually inspect the "Clocking" on your brake lamp bulbs, left and right. Sometimes improper clocking will make weird things happen with lamps. You might give a little background as to what you were doing just prior to the lamps going "Rogue". Sometimes we do things unintentionally when we think we are "Fixing" something. Just a thought. Regards, Paul |
