dash warning lights
Had to take in my 2007 Santa Fe to the shop tonight. Yesterday when I started the Santa Fe, the ESC and the ABS lights came on. The all wheel chassis light started flashing. I took out the ESC fuses, a 40 and a 10 amp from under the hood, and they were fine. Restarted, still have lights. On the way home from work, the Check Engine light came on.
This morning we had a bit of snow, so I checked the ABS, and they worked. Oddly enough the cruise control did not work. I wonder if they are somehow tied to the ESC? Should find out what the problem is by tomorrow. Will update this post. Daniel |
Brake light switch probably:
https://www.hyundaiforum.com/forum/h...ur-help-14042/ Or the wheel speed sensor: https://www.hyundaiforum.com/forum/h...anta-fe-12331/ |
Right on both counts. I pick it up tomorrow after they change the oil. $300.
Thanks, Daniel |
Daniel
You were lucky.... $300... Our 2010 Santy showed the same problems. But we only had the speed sensor replaced at a WOPPING $437.00 !!!! Warranty is over due to mileage. Time to think of taking it to somewhere other than the dealers. Not too happy. No oil change ! |
The brake switch had a short and the speed sensors needed to be replaced. Had oil changed and tires rotated for $345.
Fortunately, I have a dealership that has never disappointed me or tried to take advantage, and let me tell you there have been dealerships in the past that have, and I never returned. Daniel |
| All times are GMT -5. The time now is 04:12 AM. |
