Front end noise
Old 03-25-2008, 08:13 PM
abaton6's Avatar
Default Front end noise
I have a 2003, 70,000 mi, 2.7L. I've been noticing a bumping/thumping sound coming from the front suspension while going over rough roads. I checked the ball joints, and the tie rod ends. All look good. Engine mounts are tight. Anyone know a good way to check the strut bushings? Or any other ideas?
Thanx,
KGBrown
Old 03-25-2008, 09:33 PM
Default RE: Front end noise
Have you checked the anti-roll bar bushings and end links?
Old 04-05-2008, 03:11 PM
abaton6's Avatar
can't seem to see any play in those end links. The noise seems to be getting worse. Any other ideas?
Thanx
Old 04-05-2008, 07:10 PM
ken99's Avatar
Or any other ideas?
If not the strut bushing/bearing, it could be the shock absorber in the strut has gone bad. You can try jumping up and down on the front end while someone listens, but it's tough on newer cars to get much oscillation (not much to stand on). The only sure way I know to test these is to remove them from the car. If you have routinely driven rough roads during the 70K, you likely need new struts anyway.
jolind
03-26-2009 11:15 PM
xxfroehlichxx
11-12-2007 09:51 PM
purplnurpl98
05-25-2007 10:06 PM
nbrsguy
05-18-2007 03:13 PM
nbrsguy
05-18-2007 03:10 PM
Quick Reply: Front end noise
