Headlights burn out on 2006 Santa Fe
I have replaced the high beam and low beams lamps (both sides) on my 2006 Santa Fe more times than I can recall since purchasing the vehicle. It seems that they last on average 10,000 miles and burn out. I don't touch the lamp (halogen) with my fingers, so I know it's not a hand oil problem. I've tried different makes of lamps as well, to no avail. Anyone else have the same problem?:confused:
What type of bulbs are you using? Higher powered bulbs will have a shorter life. Do you drive on rough roads?
(Post 32709)
The roads I travel are virtually all smooth suburban roads or highways. No off- or on-road bumps to speak of. |
