Tail LIght Wire 2004 SAnta Fe
HI I can get the tail light out after removing the two phillips screws but How do I disconnect the wire so I can replace the tail light assembly with a new one?
THANK YOU!!!!!!
THANK YOU!!!!!!
You dont need to remove the wires. Just turn the lightbulb sockets like you were changing a burnt bulb and pull them all out. The new light comes with them in already if i recall correctly, so just take those out as well and put the light in. Simple!
bogey883
01-16-2011 01:56 AM
