Homelink (rearview mirror) fuse location
I hate to ask this but it's been pouring all day and my Homelink is dead (not status indicator LED etc). I have looked at the fuse block and nothing is obvious as to what fuse would be the Homelink fuse…..anyone know which one it is off hand? (no volt ohm meter at work)
Thanks all |
What year?
Did you check the owners manual? They should be listed there. I'm going to assume the newer 2007-up Santa Fe. It's the A/CON#1 fuse in the fuse box in the passenger compartment: http://www.hmaservice.com/data/Passe...scmbe6211n.gif That's the 4th row, 6th column in the pic below: http://www.hmaservice.com/data/Passe...scmbe6210n.gif |
Man I hate to answer....It's a 2010 and I looked at the manual late last night and didn't see anything regarding Homelite....and I left the manual home. I don't have a 2010 manual at work but I have a 2009 manual and it does not show it like your picture. Wish I had my manual!!
Here's the 2010 images. The fuse is still the same circuit and location.
http://www.hmaservice.com/data/Passe...scmbe0063n.gif http://www.hmaservice.com/data/Passe...scmbe0062n.gif |
Found the Problem
Well after checking the fuses....all of them. I then remembered that I had this problem before and the dealer fixed it.
I called them back and the notes said reconnected cable in sunvisor. He got the tech and the talked about it then he asked if I checked the cable on the back of the mirror....sure enough, it pushed in about a half inch but it doesn't lock into the mirror. Hopefully this will help someone...or me in a year or so....but are the connectors suppost to lock into the mirror????? Thanks again for your help |
