Honda Crv Wheel fit on a 2004 Santa Fe ?
Hi, could any one tell me if a set of tires and wheel from a 2011 Crv will fit my 2004 Santa Fe? The bolt pattern is the same, but the honda wheels are 17 inch and the Santa Fe is 16 inch? Crv tires size is 225/65/17? Just looking for a set of snow tires for my Santa Fe and came across these crv wheels with a brand new set of blizzack snow tires? Please help?
No, those will not fit (without being modified). While the bolt pattern is the same the center bore is smaller on the Honda wheel (64.1mm vs 67.1mm for the Hyundai). So the Honda wheel will not fit on the hub of the Hyundai unless you have the wheels center bore machined larger.
The tires will fit if you had correct Hyundai 17" wheels to mount them on.
