Horn and keyless entry not working.
I just got a silver 2007 Huyndai Santa Fe Limited 3.3. My wife and I are very exited about our third hyundai that will be replacing our beloved 2004 Santa Fe. (our other Hyundai is a 05 Tucson)
Well, so far I have two small things that I need to fix. First, I cant get to unlock/lock the car using the keyfob. I am not sure if its something wrong with the keyless entry system or the keyfob itself. The battery on the keyfob appears to be fine since the red LED indicator shines brightly when pressed (it blinks fast) Also the horn doest work, it might be a fuse or just loose connection but I wonders if it has anything to do with the keyless entry problem... Any idea what could it be or what to check? |
UPDATE;
The horn is now working... it was a blown fuse. |
