How do I remove the factory radio in 09 Santa Fe
how do I remove the factory radio in my 09 Santa Fe,going to install gps system
Center Fascia Panel Replacement
http://www.hmaservice.com/viewer/img/note_icon_eng.gif - When prying with a flat-tipped screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damaged. - Put on gloves to protect your hands. 1. Remove the crash pad side cover. http://www.hmaservice.com/data/Passe...scmbd6092l.gif 2. Remove the switch assembly (A). http://www.hmaservice.com/data/Passe...scmbd6079d.gif 3. Loosen the mounting screw, remove the lower panel (B). 4. Disconnect the connector (A). http://www.hmaservice.com/data/Passe...scmbd6080l.gif 5. Remove the center lower garnish (A). http://www.hmaservice.com/data/Passe...scmbd6073d.gif 6. Remove the speaker grill (A). http://www.hmaservice.com/data/Passe...scmbd6074d.gif 7. Loosen the mounting screw, remove the speaker grill (A). http://www.hmaservice.com/data/Passe...scmbd6075l.gif 8. Disconnect the connector (A). http://www.hmaservice.com/data/Passe...scmbd6076d.gif 9. After loosening the mounting screw, remove the center facia panel (A). http://www.hmaservice.com/data/Passe...scmbd6077l.gif 10. Loosen the screws. 11. Disconnect the audio connector and antenna cable, then remove the audio assembly (A). http://www.hmaservice.com/data/Passe...scmbd6083l.gif 12. Installation is the reverse of removal. http://www.hmaservice.com/viewer/img/note_icon_eng.gif - Make sure the connector are plugged in properly. |
Thank you so much for the info .......................
