How to "re-activate" the Car-Stereo, after disconnected from the Battery?
Hi,
I am frankieboy and I am posting from Germany, hoping to get some help with the following problem I currently have. As it was my original intention, to replace the factory-installed Car-Stereo (Type: "EMP301") in my Santa Fe (Type: "CM"), I disconnected the battery prior to remove the Radio. Circumstances made me change my mind and - for now - I do intend to keep that Radio. So I connected the battery again. I would have expected, that now I would be asked to type in the Security-Code to re-activate it. As per the manual of the Radio, the Display of the Radio should show "1CDE" to put in the code. But instead it showed "Code Error". Iīve tried to push several buttons. Without any success. Then I turned the tuning knob (right hand side of the radio). The Display changed a bit and a dot behind the "Error" appeared. Now the display indicates "Code Error." But moreover: nothing happened. I turned it off and on again and turned the tuning knob again. Now the Display shows "FM1 10050" (it is not exactly the number - that I donīt remember - but I think that doesnīt make any difference if I would recall it exactly). It looks like a FM-frequency indication, which I can change, if I turn the tuning button. But moreover: nothing happened. Again I disconnected/connected the battery, again hoping, that I will be asked to put in the Security Code after that. But I was wrong. Now the Display also does not show "Code Error" as in the first attempt. Now it shows the "frequency-like" indication, that I described beforehand. The Radio does not make any sound. :( Any idea, how I can re-activate it??? :confused: I would like to avoid to drive to the next dealer, which is 25 miles away. I conclude, that he would like to see money to fix it. And my guess is, that I only will need to use a very particular combination of pressing buttons to get my problem out of the way. Thank you so much! :) Greetings from Germany frankieboy |
Sorry, I tried to find some information, but I couldn't come up with much.
| All times are GMT -5. The time now is 08:39 AM. |
