ICM relay assy Hyundai Santa Fe 2006/2007
Old May 27, 2021 | 12:49 AM
Salatiga07's Avatar
Default ICM relay assy Hyundai Santa Fe 2006/2007
Dear All
I have problem with my Hyundai Santa Fe CM 2006/2007.
It has 3rd row AC blower, it was normal until 2 weeks ago suddenly can not be switched on.
I hear click sound near steering column, I guess it was relay issue. From internet I found that relay for rear 3rd row seat is located in relay assy circuit called ICM.
Anyone have experience this ? Is it possible to repair the ICM by replacing the faulty relay inside it ?
Thank you.
Old May 30, 2021 | 08:48 AM
Waltd140's Avatar
Relays are tricky, but not hard. Usually a box under the hood with relays. If that's the case, find your 3rd row relay & swap it out with another. Most of them are interchangeable so find something that works (headlights, horn) & swap the suspect relay with it. Then you know if it was the relay.
decaturbob
Oct 25, 2019 06:59 PM
wbaird1
Jul 12, 2018 03:48 AM
SantaFe_owner
Sep 3, 2012 10:25 AM
mshaughnessy45
Jun 14, 2010 01:04 PM
sharkbait
May 23, 2006 02:46 PM
