lower control arm nightmare
So I am replacing the LH lower control arm on my 2002 Santa Fe.
Should be easy. 4 bolts, out, in, done.
Except whatever Hyundai put inside the chassis as a nut started turning 1/2 way through removing one of the front bushing bolts! I can't tighten. I can't loosen. I envision cutting open the chassis, grabbing whatever they have inside, remove/replace and weld a patch over the hole. Not very elegant, so I need to ask, does anyone out there know a "trick" to avoid the surgery described!
Hellova a day to quit drinking!
Tks
Tks
Jon Hansen
Feb 28, 2012 11:23 AM
redneckidiotf1
Mar 7, 2006 09:33 AM
