Master cylinder?
My wifes 03, 60,000 mi has a brake problem. The carstops fine, but if I continue to push the brake pedal down, it will go down almost to the floor in about 5-6 seconds. There is no loss of fluid, so I'm thinking master cylinder. Any thoughts? We bought it used, so this repair is on us :( Also, anyone try Rockauto.com for parts? Good prices, fast shipping.
RE: Master cylinder?
Chances are the master cylinder needs to be changed. The plungeris worn and allowing fluid to pass by it slowly
Originally Posted by kg325
(Post 10425)
Originally Posted by hallpearl
(Post 36924)
This is totally sick i cannot find any seller in here of second hand master cylinder for a santa fe.
(Post 36924)
Anybody who knows who sells them in here?
Master cylinder not been a common occurrence on Santa Fe... I have change HECU on each one we have had for pedal feel issues..
Couple things you need to do ahead of time to eliminate possibility - Flush the entire brake system,, old fluid loses it' temp capability, so it will boil at lower temp,, possible air bubbles in system due to boiling fluid, air not compress well. Make sure calipers move freely across the mounts.. stuck pin/pins will goof the pedal.. Pads good After the system squared away and it act goofy,, then very possible the HECU is bypassing fluid internally.. HECU is $$$, add labor, bleed complete again, then run HECU bleed mode with GDS a couple time to finish. |
