Need help ?
2019 S-F 2.4L ….Having a problem starting it when it sits overnight in the garage. I push down the brake pedal and push the start button nothing happens. it takes several tries and I'm lucky if it starts, the brake pedal gets super firm. It feel like all the vacuum has bled off. The problem started just recently. Once I get it started and drive any distance it will start every time after that when warm. Has anyone else had this problem ?
The closest dealer is 125 miles from home a 250 mile round trip. |
2019? Dealer is 125 miles away?
Well, just to stay safe, Measure the voltage on the battery. 12.5 volts nominal. Clean the battery posts and cable terminals Follow negative battery cable to chassis. Clean ground. Check the alternator output voltage. |
Thank you
Originally Posted by avisitor
(Post 58985)
If this were an older vehicle then would have suggested things to check
But, this vehicle is still under warranty And do not want to do anything to void that warranty |
(Post 59002)
Problem is
(Post 59002)
But, this vehicle is still under warranty And do not want to do anything to void that warranty I'm going to buy one at auto zone tomorrow for $13.99 if it works it will be a cheap fix . |
The 2011 Sonata I have had a brake light switch recall which caused similar problems, If it works like the Sonata, you can hold the start button for 30 seconds and it should start
Originally Posted by s-petersen
(Post 59039)
Problem...It only happens when the engine is cold overnight in the garage. Once warm it starts every time first try when out and about. I thought that a new starter rely would fix the problem-no luck with that. I will ask the dealer to install a new starter and Solenoid ? Don't want to make another 240 mile *&^%$$##@@! round trip. |
I was thinking about that, overnight there is some vacuum loss on the brake booster, and he pedal would not depress as much as when just run, so that's why I was thinking brake switch.
(Post 59044)
