Need a new rear tail light 07'
Need a new pass side tail light bulb. I pulled off the panel. I see a wire and three screws. Is this all I need to take off the get the tail light out? And I think the bulb is the 1157. Please correct me if I'm wrong.
SANTAFE(CM) >2007 > G 3.3 DOHC > Body Electrical System > Lighting System > Turn Signal Lamp > Repair procedures
REPLACEMENT 1.Disconnect the negative (-) battery terminal. 2.Loose the screws (3EA) holding the rear combination lamp then disconnect the 4P connector then remove the outside rear combination lamp. http://www.hmaservice.com/data/Passe...scmbe6448d.gif http://www.hmaservice.com/data/Passe...scmbe6449d.gif 3.Replace the bulbs (3EA) after disconnecting the rear combination lamp assembly. http://www.hmaservice.com/data/Passe...scmbe6450n.gif 4.Disconnect the lamp cover on tailgate. Remove the lamp assembly after loosening the connector (4pin), Cap nuts (2EA) and nuts (2EA). 5.Remove the tailgate combination lamp assembly and the replace the bulbs. http://www.hmaservice.com/data/Passe...scmbe6451d.gif 6.Installation is the reverse of removal. |
Thanks. The pics are great. Did you find these online?
Sign up for free. |
I pulled the tail light. I got some good advice from another site. Put a rag below the 10mm nuts/screws so you don't drop them in to the bottomless pit. I bought some 1157 bulbs...when I pulled the burnt bulb it was an 1156. The tail light uses 3 different types of bulbs. One is a 1157, 1156 and what looks like a 168. Strange. Oh well....back to the parts store.
