Power window problems
Not sure if anyone else had this problem. I've got a 2009 Hyundai Santa Fe. My issue is my drivers side works and the back windows work but the passenger side rolls down but not up from the drivers control but works on the passenger side
My guess is the switch on the drivers door is bad. Unfortunately, it's a complete module that operates all 4 door windows so you'll have to remove it, test it and possibly replace it.
i had the same problem with back left window. elctric contact spray. did not remove switch just sprayed it and worked it. its fine now.
