Question on 2013 Santa Fe 2.0T Battery Replacement and other issue
Old Aug 19, 2022 | 10:30 PM
kevin307's Avatar
Default Question on 2013 Santa Fe 2.0T Battery Replacement and other issue
If anyone could kindly let me know if I would like to change my battery, do I need to reset any setting after or do nothing after replacing to a new battery?
Also has anyone has this kind of problem, recently when I start my car in the morning I will loose my throttle (like there is no turbo), and if i just drove it and have my car parked at work, after starting again the engine light would be on and will not have throttle at all until the engine light is gone.
But if i start my vehicle in the morning for like a minute and quickly ignition off and on then it has no issues. Do you think this is a faulty battery affecting this?
Thanks guys!
Old Aug 20, 2022 | 05:57 AM
Guessing can get expensive and disappointing.
See if there is some place to have the battery checked.
If it is original, 10 years says very possible.
Depending on how much use, before condemning a battery, should make sure charging system is working 100 %.
jdanniel
Nov 28, 2024 10:51 AM
billandmel
Oct 7, 2021 03:43 AM
