Radio Removal
I would like to remove the radio from my 2007 Sante Fe in order to install a mount for a satellite radio. I have hook tools but don't know what or how to remove the components to get to the radio mounts. Does anyone know the steps for removing the radio?
RE: Radio Removal
remove the coin tray, remove 2 screws then use hook tool and pull on lower piece of console. when removed then remove 2 more screws from under the upper piece.
RE: Radio Removal
I don't have a coin tray. This is the upgraded Infinity radio with the speaker in the top of the dash. Below the radio is the automatic heating/air conditioning controls. Below that is an ashtray that pops out when you press in the tray. I don't see how the ashtray comes out as there isn't a release in plain view.
On the sides of the radio are a/c vents. I've tried pulling those out with hook tools, but they also don't want to release. I have to say, this is the most well secured dash I have ever seen in a car. |
RE: Radio Removal
well ash tray coin tray https://www.hyundaiforum.com/micons/m11.gifwhen you release it there is a tab in the ash tray that you press on then you pull on the tray, try it let me know if it works.
RE: Radio Removal
I have the same problem I can't remove the ash tray or the centre air vents to access facia screws, I have a schematic showing all the screws, trouble is can't get at em!!!
The cars a R/h drive Santa Fe crtd cdx 2006 UK model. Helllllppp!!! Gazza!!! from the good ol UK! |
RE: Radio Removal
I have the same problem I can't remove the ash tray or the centre air vents to access facia screws, I have a schematic showing all the screws, trouble is can't get at em!!! http://www.hmaservice.com/ You will have to register and login. Click on the "Shop" option on the left hand side. You'll get a screen with the option boxes in the upper left. Select you vehicle model, year and engine (I'll assume the 2.7L V6). Drill down through the menus: G 2.7 V6 DOHC => Body (Interior and Exterior) => Interior => Crash Pad => Repair Procedures Step-by-step instruction for taking the whole dash apart. I guess you'll need to look at the graphics in mirror for you right hand drive version. |
RE: Radio Removal
Hi Ken,
Tried to register with the Hyundai Service Site, it accepts all ofmy info but then will not allow me into the page required, is this cosperhaps I live in Birmingham United Kingdom? Double Hellllllllllp!! Gazza!!! |
RE: Radio Removal
Try clicking on the site requirements button on the initial screen. There are 3 viewers needed for viewing the site, I'm guessing you'll need the SVG viewer at the vert least. Yes, it sort of touchy. Yes, I guess the site could be IP filtering non-US users, but I'm just a user myself.
RE: Radio Removal
Not an expert, but on my Santa Fe there is a coin tray over the radio withtwo screws, there are two screws in each side of the radio facia accessed by tilting the vents and the woodgrain trim below the radio needs to be unclipped.
The radio/dash facia clips of the radio to reveal the mounting bracket screws on both sides of the radio. Cheers Ray |
| All times are GMT -5. The time now is 03:03 AM. |
