Santa Fe 2008 stereo removal question
Hi there !
I got all the parts and manuals to remove the original radio and replace it with my Sony aftermarket radio. But i can't pull off the wooden panel below the AC control and above the ash tray ( center fascia panel). Everything is so tight you cant put a blade between the gap and i dont know where the clips are. The hmaservice.com webpage isn't much help either. There are two points to start removing the panel in my opinion, but i dont want to use force. You could pull out the ash tray and use a hook to pull at the panel or you could start just right from the ignition. Does anyone have any tip for me ? Thanks .. Lothar |
RE: Santa Fe 2008 stereo removal question
Lothar
I am trying to do the same thing...Did you ever figure out how to remove this piece? |
