Santa Fe master brake valve problem
I have a brake fluid leak where the two brake lines from the bottom of the master cylinder , they all connect into some type of prop valve where the brake lines go into... The fluid is leaking from bolts on bottom of this valve that have rubber o-rings tops to them and some type of valve inside...
I'm not sure what the part is called so I was hoping someone on here could help me out on what part it is so I can replace it.. or rebuild it or something...:(:confused: |
