Spark Plugs
Old Apr 21, 2009 | 05:12 PM
robweidman's Avatar
Default Spark Plugs
Has anybody switched from stock spark plugs to the Bosch Platinum+4 (4 ground electrodes)? I'm curious if you noticed any performance difference. In my applications, I have not. If anything, I believe the performance is less. Perhaps this is due to the timing not being adjustable - or is it? It seems to be that if you use a more efficient plug, the timing could/should be modified to be less advanced, thereby increasing power. Otherwise, you might disrupt the timing curve and achieve poorer results overall. Thoughts?
Old Apr 21, 2009 | 06:03 PM
jsinton's Avatar
Banned
Yes, it's a less efficient plug. No, you can't adjust them. Advancing timing INCREASES power and efficiency, not reduces. Timing is computer controlled on these modern cars anyway, so it's not normally adjustable.
I just use cheap platinum plugs, and reduce the gap more than spec a little for better efficiency. The spark fires a little faster, thus it advances timing, and I get better MPG. Increase the spark plug gap if you live in a country with lower octane fuel so it runs better.
KingEvil
Dec 5, 2008 12:48 AM
greatbison
Dec 5, 2008 12:46 AM
joe
Jan 17, 2008 07:35 AM
Boomer
Apr 23, 2006 03:36 PM
joe
Oct 24, 2005 01:26 AM
