Speed sensor...again
Old Jan 1, 2012 | 12:42 PM
command_z's Avatar
Default Speed sensor...again
I know this has been covered 100 times, but I still need help. Have all the usual suspects, limp mode, hard shifting, code 0715. I replaced the input speed sensor. It did not help. Still same 0715 code. I used contact cleaner on the plug...no help. I would think that if the output sensor was bad it would throw a 0720 code. Suppose that the new sensor is bad? Would a bad output sensor still cause a 0715 code somehow? I don't have much hair left from battling this problem so I need it fixed real soon
2002 Sante Fe 2wd / 2.7 engine
Old Jan 4, 2012 | 07:56 PM
command_z's Avatar
Problem solved! Replacement sensor was defective.
xg350
Mar 13, 2010 04:14 PM
drov
Oct 1, 2008 10:34 AM
liepinaanna
Off Topic
Nov 17, 2007 10:38 PM
organic53
Jun 29, 2007 07:55 PM
TheDave
May 18, 2007 02:46 PM
