Subframe
Old 06-19-2018, 04:27 PM
Roz's Avatar
Roz
Roz is offline
Default Subframe
shop told me my subframe needs replacing and lower control arm and it'll be $1800...any other options because that's too much money
Old 06-19-2018, 04:48 PM
avisitor's Avatar
Options are to do your own work and maybe lots of welding
Seriously, check to see if there is a recall on your vehicle
Hope for the best. Also, start saving for another car.
Old 06-19-2018, 04:52 PM
Roz's Avatar
Roz
Roz is offline
Where do I check for recall on my vehicle
Old 06-19-2018, 05:00 PM
Roz's Avatar
Roz
Roz is offline
No recalls I just checked
Old 06-19-2018, 09:44 PM
avisitor's Avatar
Sorry
Old 06-20-2018, 04:10 PM
A lot depends on the present condition of your vehicle.
If it has been neglected, there is always a price to pay for neglect.
If on the other hand, it is in decent shape otherwise, sub frame replacement isn't that difficult a job. You will need some equip to hold the engine up while doing the job and an alignment will be required when completed. Only you know what you have and sometimes it is cheaper in the long run to repair than to replace especially with a used vehicle because how many people do you know that got rid of a perfectly good vehicle. You guessed it , it needed some expensive repairs or has a problem that no one could correct. Were you able to get more than one estimate?
Old 06-20-2018, 06:16 PM
Roz's Avatar
Roz
Roz is offline
Yes I got another estimate they said $2400!! Priced a subframe used $80 so me and a buddy gonna install subframe control arms ball joints and sway bar...I'll keep y'all updated
Old 06-22-2018, 02:33 PM
avisitor's Avatar
Thanks. That would be great to see how it is down.
Or at least do a write up
Good luck
Old 06-24-2018, 01:09 PM
Roz's Avatar
Roz
Roz is offline
Friend did my subframe and replaced the control arms ball joints sway bars..had wheel alignment drives good now ��
Old 06-24-2018, 02:34 PM
Thanks for the update .
Pugwash
03-19-2024 12:14 PM
TucsonIowa
11-18-2018 08:50 AM
Smity
08-01-2018 06:25 AM
jadedangel421
02-29-2012 08:39 AM
PenguinHead
01-01-2011 05:52 PM
Quick Reply: Subframe
