Switching from XM1 to XM2 radio on 2014 Santa Fe Sort with Infinity radio
I turned on my radio to listen, but was surprised to find that my XM1 stations were not there. So I reset them. But then I noticed my radio was set for XM2.
What happened? I can't see where to switch from one feed to another like my 2010 Sonata. It can be switched easily. Thanks, Daniel |
Still don't know why my XM stations switch from XM 1 to XM 2. Today it went to XM 3! BUT, I did figure out the only way I can switch from one feed to another is to use the "voice" button on my steering wheel. I press the button and say, "XM one."
I thought for sure there was another reason the station feeds were changing, and it would be an easy fix. However there is NOTHING out there on the web that answers my questions. =-/ Daniel |
Maybe you lost the data from a power loss. Send the activation code again and you'll have to switch to the correct channel to get the downloaded database. I forget which one it is. Maybe 115 but its on their website somewhen but on on this link for reactivation. https://my.xmradio.ca/ActivationRefresh.aspx
| All times are GMT -5. The time now is 05:49 AM. |
