Tail LIght Wire 2004 SAnta Fe
HI I can get the tail light out after removing the two phillips screws:) but How do I disconnect the wire so I can replace the tail light assembly with a new one?:confused:
THANK YOU!!!!!!:p |
Help
is it IMPOSSBLE??:(
You dont need to remove the wires. Just turn the lightbulb sockets like you were changing a burnt bulb and pull them all out. The new light comes with them in already if i recall correctly, so just take those out as well and put the light in. Simple!
