"TCS OFF" "ABS" "BRAKE" lights on
2005 Santa Fe, 3.5l
All, I have the following lights on, on my dash. "TCS OFF" "ABS" "BRAKE" They all came on at the same time when making a normal turn at an intersection. The car is still operating like normal. It is having NO stopping issues not any other drivability issues. I have checked the following: Tone ring (both driver and passenger)....GOOD not broken and not dirty! ABS fuses(2 under hood)....GOOD Brake switch under dash (tested with my ohm meter)...GOOD Brake fluid...GOOD Any other suggestions? |
Did you test the wheel sensors?
Here is the update. I tested the wheel sensors today. The OHM test reads 1.305 on both wheels and the AC voltage test while turning the wheel went up the faster I turned the wheel.
I cleaned each of the wheel sensors (there are only 2 in the front). I disconnected the battery for about 15 minutes to see if that would work. I checked the brakes on all 4 wheels to see if maybe it just needed pads. (NOPE) . All 3 lights, (TCS, ABS, BRAKE) all come on as soon as you start the car and never go off. I would think that the ABS light would go off when the car is started and then come on as needed if the tone rings were bad (which I checked again and they are not cracked or dirty) I guess I will have to find a computer that can read ABS codes. The one at the parts store wouldnt do it. |
