Stalling issue at startup
Old 04-18-2008, 02:12 AM
rtrefz's Avatar
Default Stalling issue at startup
Hi. I just ran into an issue with my 2003 Santa Fe (4 Cylinder model) ~ 53k miles.
I can start my car. However, it stalls out after ~ 3 seconds. Revving the engine doesn't help. The check engine light stays on, but I don't have a decoder. Fuel is at 3/4 of a tank, from the place I usually gas up the car.
Any ideas? It's kind of a moot point, since the car is at the dealer's, but I'm curious about potential causes of the issue. Thanks.
Rob
Old 05-17-2008, 10:02 PM
Default RE: Stalling issue at startup
Just wondering if they figured out what the problem was?
My 2002 Santa Fe is doing the exact same thing. Starts up just fine, runs for exactly 3 seconds, then dies.
Its been to 2 different shops - they don't know what the problem is.
Old 05-20-2008, 10:32 PM
madindian1's Avatar
the crankshaft sensor is going bad
Old 05-21-2008, 03:34 PM
How should I check it?
If I unplug it car does not even try to start.
It has 3 wires: one of them is 12V, one of them is ground, and the other one has 5V.
bamawig
04-07-2013 03:12 PM
scottyboy1190
03-07-2012 02:13 PM
CSilivestru
01-21-2011 06:57 AM
bobisnext
12-03-2007 10:42 PM
mwiltse
10-12-2007 09:46 AM
Quick Reply: Stalling issue at startup
