-   -   Tools for 07' Santa Fe rear brakes? (https://www.hyundaiforum.com/forum/hyundai-santa-fe-20/tools-07-santa-fe-rear-brakes-12084/)
Fishy5 Jan 16, 2012 09:16 PM
Going to replace my sis in laws rear pads.
Questions:
Any specialty tools required?
Size of C-Clamp needed for caliper squeeze?
12 pt or 6 pt socket size for caliper removal?
I dont have my old $50k tool box any more so if I have to get anything I need to know in advance.
Thanks tons for your help.
NovaResource Jan 17, 2012 07:51 AM
My questions to you:
- FWD or AWD?
- Are you replacing the rotors or just the pads?
- Are you also replacing the shoes for the drum parking brake in the rotor hat?
Answers to your questions:
1. No
2. Screw C-clamps, use this instead:
http://shopngarage.com/blog/wp-conte...PistonTool.jpg
http://www.greenhybrid.com/share/fil...5/DSCN3359.jpg
3. 6-point
PROCEDURE TO REPLACE REAR BRAKE PADS
1. Loosen the guide rod bolt (A) and pivot the caliper up out of the way.
http://www.hmaservice.com/data/Passe...scmbr6517d.gif
2. Replace shims (A), pad retainers (B), and brake pads (C).
http://www.hmaservice.com/data/Passe...scmbr6521n.gif
3. Push the piston in the cylinder using a SST (09581-11000) (or the tool I listed above)
http://www.hmaservice.com/data/Passe...scmbr6519d.gif
4. Pivot the caliper down and tighten the guide rod bolt.
Tightening torque (lb-ft): 15.9 ~ 23.1
5. Installation is the reverse of removal.
Fishy5 Jan 17, 2012 08:21 AM
Thanks for the response.
FWD
Just pads
no on parking brk
Nice little tool. Not sure where to get it, probably more expensive that a simple C-Clamp. But sure, easy nifty tool.
6 point socket, any idea of size? Presume metric? Being an old dog that only bought american and used sae I'll have to buy the socket, trying to have everything ready & not turn it into an all day affair having to go buy tools after the job is started.
NovaResource Jan 17, 2012 10:12 AM
Not expensive at all. Most auto parts stores carry them. Probably less than $10. Here online:
Amazon.com: Advanced Tool Design Model ATD-5050 Disc Brake Pad Spreader: Home Improvement
Amazon.com: Car / Truck Disc Brake Pad Spreader Puller: Home Improvement
Yes, metric. I want to say 12mm but I don't know that for sure. But that's usually the most common size.
