V6 with misfires on 1,3,5
I have a 2002 Santa Fe with the V6 that continues to run rough. I have replaced the plugs, wires and the ignition coil pack.
The computer codes keep reporting misfires on cylinders 1,3,5. I have a Snap-On solus scanner FYI, if there is any thing that needs to be check with that. Could this be a sensor problem or something else? |
Hi there have you tried swapping the leads about.
Replacing the Crankshaft position sensor took care of the misfire codes.
